I'm looking to install lighting in my garden, part of the requirement is that the circuit is hooked up to a photocell so that by default they will illuminate at night. As our bedroom window may suffer glare there will be occasions when I want to manually override the photosell and turn the lights off. Simple enough right?
The catch is that I'm security conscious and want a PIR to activate the lights should motion be detected when the photocell has been set to 'off'. So we have three states 1) Photocell active 2) PIR active 3) All off
It looks like what I am after is a single pole, double throw switch right?
Problem is I cannot find a internal 'metal clad' or exterior switch to do this? Any help appreciated.
