Single Pole Fused Switched Spur? | on ElectriciansForums
Discuss Single Pole Fused Switched Spur? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I'm new to this forum and the trade so please be gentle!
I've recently rewired a kitchen with 7 appliances on one ring circuit and each appliance has a switched fused spur to isolate the related socket.
I'm only switching the live in each spur, so the neon on each spur is not lighting up (sockets are working though).
Is there such a thing as a single pole fused switched spur with a neon that I could use instead?
It's not possible to run another cable now so that i can use the double pole spur.
Any help is greatly appreciated.
Why?
Do you mean you haven't connected the neutral to the switch?
You don't want a SP switch.
You shouldn't need to?
Did you IR test the circuit before energising? If so and carried out incorrectly you may have blown the neon.
Also, 13A connection units should not protect sockets that use a 13A fuse in a plug due to discrimination issues. This is where 20 Amp double pole isolators should be used.
I personally avoid neons like the plague, if there is a way of not using them than that's the route I opt for. Sometimes though it is necessary to use them to indicate that a certain device has been left on.
:thumbsup
I'm confused as to why your only switching the live and not the neutral aswell.....doesn't sit right with me at all.
Double pole switching should be the norm in my opinion (i only install DP sockets and wont entertain the single pole stuff (light switchs are a different story of course))
Double pole switches as has already been suggested is the way to go if supplying socket outlets due to discrimination as 1shortcircuit says. I'd only use Double Pole switch fused spurs if the appliances were wired into a connection outlet plate instead of a socket so it would have fused protection.
Have you wired the SFCU like a light switch and taken a loop T&E (Line and switched line) from the socket and up to the SFCU?
This is the only way I can see that you would be able to only switch the line and not have a neutral available to connect.
This is not an appropriate way to wire this.
If you have wired it so that you have taken the supply to the SFCU, only disconnected the line core so as to switch through the SFCU and then taken the cable to the socket then you should be able to modify this so that you can also connect the neutral in the SFCU and get the neon to work. (The cpc should also be connected in the SFCU).
I've read the opning post ten times now and I think what he has done is to terminate the supply and load neutrals in the load side, the live as per normal (of a dp fsu) but connected the neon N to the load term and thats why it/they dont light up but the sockets work.
Its too late to look at the op again just trying to work out what is happening and what he wants. Hope h comes back to us in the morning.
Morning all and thanks for the replies.
I'll try and clarify what I have done.
The live that would normally feed the socket (if there was to be no SFCU) is going into a connector block with the live to the next socket.
Also in that block is the live of a separate T+E cable which runs to the SFCU supply live terminal.
The neutral core of this T+E is connected to the load live terminal of the SFCU and back to the socket live terminal, feeding the socket.
So the socket works fine but the neon doesn't light up, which I assume is because there is no neutral being switched in the SFCU.
Is this a legal or accepted way of doing this as it's being tested this morning at 11 !
In truth if i was to turn up to test the circuit described i'd take one look at it....likely go outside for a smoke, return to have another look and fail it just on visual inspection (while slowly shaking my head thinking wtf?).
It's not a lightswitch...it's a double pole SFS which requires switching of Live and Neutral...the clue's for a novice are on the switch to be fair
Reply to Single Pole Fused Switched Spur? in the UK Electrical Forum area at ElectriciansForums.net
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
J
The rcd spur being fitted is probably because there wasn't rcd protection of that supply.
