Hi, I want to put downlights in my fire surround - possibly 3 but more likely going to be 2. They are 0.4w LED lights. I have a 12v 8w LED driver with a 6 way TOP connector on the end. I want to add an on/off rocker switch but I'm confused as to whether I need an SPST or an SPDT switch for this. Any advice would be much appreciated.
Both will switch them on and off but the SPDT can be three position, on-off-on so you need to remember which way to switch it so SPST is best. Are you switching the 12v side if so then the driver is permanently powered.
United Kingdom
United Kingdom
Single Pole Single Throw or Single Pole Double Throw Switch?
DIY Electrical Advice
Woodsy,
westward10,
