Dray
Hi all.
I need some direction to supplying power to an electric boiler that requires 3 phase. boiler output is 36kw. I have had a bit of a search on tinterweb and only motor supplies seem to be coming up. I'm assuming that the boiler has Three heaters and each needs it's own phase. If any of you could point me in the right direction that would be great. Thanks
