drew35
I don't usually get involved with singles run in conduit but I'm wiring a workshop and the customer asked for conduit and singles, but he has asked me to do a couple of things which I'm not to sure off.
1. To save cable, instead of running cable down the socket drops and back up, and then along to the next socket, he wants me to use crimps at the top of the socket drop so there is only the three singles down to each socket. I don't like relying on crimps but I couldn't think of a regulation against it?
2. Again to save cable, I'm running three banks of fluorescents and he wants each bank switched separately, from different locations. I was going to run a separate circuit for each bank via a 1g switch. But to save cable he wants me to through wire with the neutral and cpc to all of the lights, then take the live to the first switch and piggyback a live from the supply side on to the next switch. Is there anything wrong with that? Again no regulation sprang to mind, I will go through the book later but any advise is gratefully received.
Cheers.
Cheers.
