Six point method | on ElectriciansForums
Discuss Six point method in the UK Electrical Forum area at ElectriciansForums.net
B
bobeemick
Can any one help me answer a question I've come across in the HNC fault finding module.
what is the six point fault finding technique.
the British Gas 6 point method.
1. stare at CU with a thoughtful expression.
2. remove CU cover
3. shake head whilst tutting quietly
4. try to reset tripped device
5. plug in socket and see tester.
6. quote ÂŁ800 + VAT for a new CU
2. remove CU cover
this must be the first ammendment then Tel...
i mean what happened to :
"vaguely wave the volt pen over it whilst trying to look like you know what your doing"?
Reply to Six point method in the UK Electrical Forum area at ElectriciansForums.net
thanks for the confirmation this is what i thought. i cant think of what use this device is . i have seen David Saverys Arc Fault Detection Device...
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
