Size of earth on tncs system | on ElectriciansForums
Discuss Size of earth on tncs system in the Australia area at ElectriciansForums.net
F
fredrico
Am i right in saying that you had a 10mm earth wire from the service head to the consumer unit on a tncs supply, measure the ze, and use this value to work out your fault current, and put it into the adiabatic equation, then if the value was ok, leave the 10mm in place, instead of replacing it with a 16mm earth wire?? If there were 16mm tails from the cut out to board.
Reply to Size of earth on tncs system in the Australia area at ElectriciansForums.net
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
