sunnybrook
As there appears to be a forum for "professional" electricians, I guess amateurs can post here. Also, although the question refers to using a product in Bulgaria (230v, 50hz), I guess the theory would apply in the UK, so bear with me please...
We brought a log splitter back from the UK and it works beautifully but we have a question about the electrics. We have emailed the manufacturer and seller but they have not responded.
It has a 2200W motor. It is designed for European market as the built-in cable has a European plug. It comes with a 10m extension cable with European socket and UK plug. Changing the plug is no problem.
We have used it no problem close to the house. We would now like to use it near the garage, which is about 18m further than the provided cable will reach. Max. permissible cable length, according to the manual, is the 10m cable provided (2.5 sq mm, we assume, as that is the rated cable for it).
They say.."A longer cable impairs the motor performance and consequently the function of the log splitter." We assume that is because of voltage drop but, are there other factors?
If we had a 20m run of (radial) cable circuitry in the house walls and plugged their extension cord in at the far end, supposedly that would be acceptable. It may sound naive but what is the difference between that and running a 18m cable from a socket at the house, which is 2m from the supply, and then plugging their extension cord into a socket attached to the end, so long as the thickness of the cable used is appropriate (or, even, replacing their cable completely with a 28m run of cable of appropriate thickness).
So, what thickness would be required, in that case? The best we can buy locally is 3.6 sq mm stranded 3 core, although it is expensive, and all the tables that we have read on voltage drop seem to imply that that is really no worse than their 10m of 2.5 sq mm.
