Size of main bonding | on ElectriciansForums
Discuss Size of main bonding in the Electrician Talk | All Countries area at ElectriciansForums.net
Okay chaps, I need a dispute settled so thank god that he created the iPhone. How do u work out the size of the bonding to the gas and water in an industrial premises? Any takers please
Cheers
Moosey
on a power station i jsut finished on, evertything was a minimum of 70mm2 and theyb ran 240mm2 bare earth along all of the ladder rack! slightly over the top!
dont know about your situation though matey. Isnt there guidance in a guidance note, installation designers?
According to Section 544 in the BRB;
If not PME The cross sectional area of a bonding conductor need not exceed 25mm2, but if PME on site then a bonding conductor shall be selected according to the largest neutral conductor.
Table 54.8 ~ Where PME conditions apply
Copper equivalent cross sectional area of the supply neutral conductor in relation to Minimum copper equivalent cross-sectional area of the main protective bonding conductor
35mm2 or less = 10mm2
35mm2 up to 50mm2 = 16mm2
50mm2 up to 95mm2 = 25mm2
95mm2 up to 150mm2 = 35mm2
Over 150mm2 = 50mm2
Cheers notsosmart, I thought it was to do with the neutral supply conductor and I was sure 50mm was max. It's a factory with a supply transformer on site I take it that rule applies then...
Cheers
Reply to Size of main bonding in the Electrician Talk | All Countries area at ElectriciansForums.net
UPDATE, after contacting Paypal, uploading all the emails and evidence the sending the transformer back I have now received a full refund...
I don't think I'd use it mate even the one line heading then one long paragraph screams ai. And untrustworthy. I don't think much has been edited...
    • Optimistic
