sizing inverter | on ElectriciansForums
Discuss sizing inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all
Got a 10 k.w installation with 40 lattitude 240 watt prismatic panels on a south facing roof, 35 degree pitch. Can anyone reccomend an inverter to suit this?
Thanks in advance
powerone pvi 10? good english technical support and a very efficient flexible inverter, but there are so many makes to choose from..........
we have a 50kw job coming up in January and will be using the PVI 10 bigger brothers trio 20 and 27.6 inverters, as with a lot of gear, when you fit a lot of one make you forget about its certain problems and just work round them, we have found that the powerone inverters have virtually been a do everything well bit of kit for us, coupled with the standard 10year warranty and I believe they pay a certain fee for removing and replacing a warranty failure (not something a lot of companies offer) other inverters are available......
Reply to sizing inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
