J
jase31
DNO has upgraded service fuse from 30a to 60a, they do not want to go any higher due to the main feed cable.
CU is 4-5m away, connected via switchfuse. Should 16mm or 2mm tails be used, OSG recommend 25mm but seems to assume a 100a supply.
With a 60a head, what size switchfuse should be used for discrimination?
