N
novolts
Hi Guys
I have been asked to quote to install a MET for a TN-C-S system and I could do with some advice please
I can't get into determine the size of the conductors as I cant switch the power off to open up the main panel
What I did was measure the circumference of the SWA it was 214mmm I divided this by 3.14 this came out to 61.8mm
diameter,I cross referenced this with cable manufacturers data sheets and the condutors are 300mm( 4 core SWA )
if my calculations are correct then the CPC would need to be 150mm and the bonding conductor 50mm
I found a label stating that the Ze was 0.03 ohms
Am I on the right lines or should chuck it all in and try and get a job at my local supermarket stacking trollies
thanks to all
kind regards
John
thanks to all
kind regards
John
