sky communal for flats | on ElectriciansForums
Discuss sky communal for flats in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
L
lee mcgregor
good evening people i wonder if you could help me , client has ask me to install a sky dish onto roof of block of flats for getting sky into everyone , i understand i need a 75 " dish and a special quattro lnb . but then after that do it just take it into loft with a splitter ??
your help is greatly appreicated
i dont want to sound nasty but TBH if you don't know i would pass the job on to some one who does, i have been a Sky Approved communal installer for 7 years, it is far from as simple as wack up a dish and split the signal, there is a lot of things to take into account.
how many Flats need feeds ?
distance of each one from dish?
Quad,Octo or Quatro LNB ?
cable type and size based on calculated losses.
then you will need to calculate the loss across the cable and compensate for it on each flat depending on distance.
the basics are you ned dish either feeding the rooms directly from a Quad or Octo LNB for up to 8 feeds, however if more are required you need a Quatro with a multiswitch, depending on the building and layout you may need to cascade them to prevent loss over large distances.
however as i said iv been doing this for years as there is no simple answer, my Promax Spectrum Analyser cost over ÂŁ2k bought specifically for doing these jobs, people think its easy to put up and aerial or dish, like any trade to do it properly it takes years of training and experience.
HUNDLETON ,
I totally agree with you and its not me thats doing it , it is actually a friend of mines that works for skythat will be doing it . the problem i have is he's on hoilday until the 12th and the scaffold is suppose to be coming down on monday (12th) . there are 8 flats with 21 dual sky cables some flats have three some two . i want that dish mounting whilst the scaffold is there as its 4 floors high . although i will prob get someone local to do that part . it just to know which equipment to have ie . lnb , dish , for the install so if i get someone they can just come and mount dish .until friend gets back then he can take it from the loft space downwards
Reply to sky communal for flats in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
