Sky Dish cable | on ElectriciansForums
Discuss Sky Dish cable in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
dedwards96
Hi,
I have a 4way LNB on my sky dish but only 3 of the ports are in use. I also have an unused sky box.
What is the cable called that goes from sky dish to sky box? and where can I get it from?
Thanks, Dan :)
Personally I do not recommend using screw on F connectors outside, they do break down a lot more often then compression type F connectors, even when used in conjunction with self amalgamating tape. I know many people use the screw on type, but if the dish is high up and access may be a issue once fitted, you are better off using compression type.
RG6 cable is the minimum I would use for satellite, the screw on F connectors work fine just remember to seal the joint at the LNB with self-amalgamating tape ( I use black insulation tape works ok too ) also try not to move the dish about with screwing the new cable into the LNB
Reply to Sky Dish cable in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
BT for home broadband. Sky for TV and Voxi (vodaphone) for mobiles. Now BT are advertising “wifi7” …. What the heck’s that?
I guess you don’t want to miss those little mermaid episodes 🤣
