steve447
Current set up of Sky + in living room.
There is a terestrial ariel point in the wall but i dont use it as its quite far from the TV so only plug a lead in when and if i require it.
My aim was to connect up the from the ariel point to the sky box, come out of the sky box to a splitter/booster box and run a coax to each room from there.
I know i will only get the same channel on the upstairs TV as in the living room, but will it also send the freeview signal too to the rooms upstairs?
