Good evening. Getting confused with it.
My client would like to have a telephone,sky,freeview,cat6 rj45 in each room.
This is a 3 bedroom house.
Can someone explain me what is the best wiring options for my situation.
Should I use some loft box or something similar ?
Can someone maybe send me a wiring diagram for this ?
Thank you very much.
You want a round sky dish with Quattro LNB , TV aerial and a multi switch. Run 4 x WF100 cables from dish to multi switch and 1 from aerial to multi switch. From multi switch run two WF100 cables or use twin WF100 to each room/2gang box.
For the telephone run a Cat5/telephone cable from the master point to the 1st 2gang box and loop in and out to the other rooms/2g box.
For the rj45 connections run a cat5/6 to each room/2g box back to the router position.
Use a 2g modular wall plate in each room with a BT module, rj45 module and and quad module/decombiner for the TV and 2 x satellite connections. The decombiner will separate the sat/tv signals.
Thanks for reply and help. Do you have some good multiswitch which I can use ? Also i dont know where they have master point of bt line. Can i run cat5/6 outside of the building and then bt company will connect it ? Thanks
