SMA Power plugs | on ElectriciansForums
Discuss SMA Power plugs in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
margate
Contractor has lost the power plugs off SMA2500HF. I think they are Cloverleaf shaped so maybe a C6 to C13 adapter would work to then use standard IEC leads off the shelf. Anyone know the type of plug into the inverters for sure?
Reply to SMA Power plugs in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Thanks very much - again for your input. It is a moulded-on plug. The first thing I did was change the fuse - which looked, and no doubt (now)...
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
