Small garage circuit | on ElectriciansForums
Discuss Small garage circuit in the UK Electrical Forum area at ElectriciansForums.net
York
I've mocked up a small garage circuit, does this look fine, any issues? thanks
[ElectriciansForums.net] Small garage circuit
personally I would go bigger than 2.5 to the garage from the inside DB, you will use all sorts of power eventually, 2.5 is too small really, and go bigger than a 20 amp MCB via the RCD as well, JMO.
Better to adapt/convert the house CU so that the garage is fed from an MCB that is not RCD-protected.
(aka a "high-integrity" CU - who invented that ridiculous title?)
Locate the RCD at the garage end to replace the isolation switch. Then, if there is an earth fault, that will only trip the garage RCD and not half the house.
The SWA does not need RCD-protection, as it runs all the way from the house CU to the garage.
Reply to Small garage circuit in the UK Electrical Forum area at ElectriciansForums.net
My wife’s Evoque gets about 32 miles on a full charge and I get about 28 miles on my F-Pace. I don’t know how long a full charge takes but I...
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
