Small power | on ElectriciansForums
Discuss Small power in the Talk Electrician area at ElectriciansForums.net
Lc1
Anywhere
I have been given the preliminary design of the small power system for an industrial complex. The design states that a switched fused connection unit should be on its own circuit , would this not normally be part of the ring main? Has anybody seen this before ?
Depends on what load is on the switch fuse, it's a good idea to have them on here own to prevent loading up the ring, especially in a industrial complex where the ring may be getting used extensively for power tools ect. There are many reasons to put the switch fuse in its own circuit.
If that's what the designer/ customer wants, that's what you need to quote for.
The Commercial buildings I work on have many dedicate single SFU circuits.
It's not unusual at all.
Reply to Small power in the Talk Electrician area at ElectriciansForums.net
AVR's and Generators in a rack??? And only at 7.5kW?? What are you actually trying to build?
Thank you. Correct on all points. :tearsofjoy::tearsofjoy::tearsofjoy:
    • Optimistic
2 3
