Smart lighting garden system | on ElectriciansForums
Discuss Smart lighting garden system in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
Somerset
got a job coming up, need to control 4 lots of lights on a garden, will have 4 zones aroind koi pond and decking etc...
First thought was a wise systemWise system
but customer wants an app for it on his phone. Anybody got suggestions for a decent wireless control system that has a phone app?
Pond area has excellent wifi coverage from main house. So connectivity is no issue.
Suggestions welcome
Have you installed the lighting yet? 've Hue lighting in my garden, only because I already had some in the house. Its bit expensive, but loads of apps for it. Its more of a diy approach IMO. But it works quite well for me.
There's quite a few products out there. If I was starting again, might of gone for some Collingwood stuff; but then you'll need a second mortgage.
Customer has full rako set up in the house. Money no object.
I have used Lightwave RF to control 96 lights on about 6 zones. However after a few relay box failures i have used the relay box to bring in a contactor per zone. Its cheap as chips, is reliable, has app and been in a few years now. Client gets a remote and as long as the stuff is in reasonable range of the remote all is good. Client has several remotes and can switch them on from numerous rooms.
I have a sort of app for my lighting, but as i don't have an iPhone, and it would take me a liitle time to call it up and open it etc, I just use the "app" that came with the lighting...I believe it's called a "switch"?
You get off your a**e and press it, and so far it hasn't failed once...plus I never lose it as it's always just where I left it!
Naturally, I can't switch the lights on from Australia, so bit of a bummer there...but it suits me...
[automerge]1569148474[/automerge]
PS: Never been to OZ, ain't going ever, just saying, in case someone thought I was deliberately misleading members on here!
Bet your tv hasn't a remote, and are you still using tapes in your VCR? :)
I've used Light Symphony kit on a few projects now. Good kit, fairly simple/basic app but does the job. If you decide to go for it register a trade account at lightingforgardens and buy it through them, it's the cheapest way I found to get it. Other good kit would be RF Solutions, they have some real long range stuff
How about Loxone ? Just wire each lighting circuit and pump back to a central place where you can install the PLCs.
Phone app is free, you can add wireless motion sensors etc.
Whatever system you choose most of the hubs need a ethernet connection back to the router.
Reply to Smart lighting garden system in the UK Electrical Forum area at ElectriciansForums.net
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
