Smart speed control for in-line fan | on ElectriciansForums
Discuss Smart speed control for in-line fan in the UK Electrical Forum area at ElectriciansForums.net
SandyM
Horsham
Hi. Advice pls. I’m a chippie not a spark so pls be kind.
I have a Manrose inline fan MR MF150S and a speed controller VL HS10 all from TLC and installed by a spark which all works fine.
Q. Can I get a smart or remote controller to replace the variable speed controller?
I also have Quinetic switches in the house which I like and can dim the LED lights with, so, the perfect solution would be if Quinetic do something that would control the speed of this fan.
Thanks in advance.
Whats it doing ?
It can be hard to see the need for all this smart control of basic items
The smartest control is probably when the fan does its job without any user intervention
Reply to Smart speed control for in-line fan in the UK Electrical Forum area at ElectriciansForums.net
Yes the neutrals will be connected together in the same terminal and the earth joined in a 2screw earth connector just behind the switch.
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
