I am replacing a 2 way switch with a smart switch. The old switch has three sockets - common, L1 and L2. I can see where the wire that went into 'common' goes on the new switch, hit the new one also has 'P' and 'L' instead of L1 and L2 - which wire goes where?
The old switch is part of a 2-way (or more) switching but not the end which takes the L and feeds the dimmed output to the light. I'd say the new "switch" (dimmer) would likely be installed at end of the 2-way switching that has the L feed and connection to the light. Does that make sense? In other words, I'm thinking you are trying to fit it at the wrong end of the 2-way switching.
Edit: I'm also not convinced it will support 2-way switching with one switch as a conventional switch.
Did you not get an instruction leaflet with the switch, showing the connections?
Perhaps someone who has actually used these zigbee dimmers can confirm or correct me.
Sussex
United Kingdom
Smart switch wiring advice
DIY Electrical Advice
Philwdavies,
SJD,
