Evening guys,
Ive got a smeg under unit oven. Everything is working apart from the heat when the oven is turned on. The fan and light come on but no heat. I'm no good with appliances, but I'm guessing the element. Can anyone tell me a test I can carry out to identify the problem?
Cheers fella's
Do a continuity test on the live an neutral of the element if it's good u should get a low ish reading depends on wattage usually when ****ed u will get no reading at all
Smeg oven advice?
Ross1,
jpm646,
