smoke alarm certificates | on ElectriciansForums
Discuss smoke alarm certificates in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
G
Guest123
Re: Domestic smoke detectors?
The only forms I've used are NIC ones.
I've attatched examples of the green ones that anyone can use......
Hi ,have been asked to carry out periodic inspection of church and seperate church hall.no problem however they have also asked me to test smoke alarms (mains wired interlinked) and the emergency lighting(stand alone units) and provide certificates for fire officer. I have managed to find some certificates on the net for emergency lighting but nothing that seems suitable for the smoke detectors,anybody point me in the right direction? cheers Paul
just print your own with all the results on, as long as you have a record then it proves you have done the required tests, and covers your arse
i use these forms.
  • Installation Certificate - Pt.6 2004 with variation.pdf
  • fire alarm inspection.pdf
Reply to smoke alarm certificates in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
I have seven Aico alarms in the house and in four in sheds in the garden and a barn over 10m away all radio interlinked, the test pad in the...
