M
mercanlandy
Hi, when you do a complete/full rewire on a domestic property which must have smoke and heat alarms installed is it a requirement of BS 7671 that a certificate must be completed for the new smoke and heat alarms as well as the new installation certificate. Typical properties are 2 up 2 down terrace houses. I have read in the NICEIC test and inspection book that you have to and am just checking as I am costing work and wish to factor in this element of the job if it is mandatory.
Regards
SC
Regards
SC
