Smoke alarm | on ElectriciansForums
Discuss Smoke alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
A
aaelectric
Have 3 smoke alarms in a house which are supposed to be interlinked but are not. The red light flashes every minute or so. Would this be because they are not interlinked. Green light is constant and are all new alarms?
think you'll find that the red flashing every minute is either normal or a sign of weak battery, depending on the make and model. usually, however a weak battery will give an audible warning. suggest googling for makers instructions.
Where are you seeing t&e?
At the board? That'd be normal.
At all bases? Someone used the cpc as interlink?
Get the leccy back and get some radio bases installed if no link
They are aico and are not interlinked as they are using two core t&e
If they are Aico's check for radio link bases if there's t&e in everyone. If there is not any, shouldn't be hard to fit.
I've got a feeling the red light is battery low, but not flat as it will beep then. They also flash red to say they have been activated but silenced.
Best check the manufacturers instructions.
Reply to Smoke alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Thank you all, yes I didn’t think they do and I have done minor works but the helpline was not very helpful. Got my yearly assessment soon so I...
That will only count when the alarm is active o/p said tamper. O/P doesn't seem to be in any rush to give more info, so I doubt anyone else will...
