Can anyone confirm to me!!! ...... I received a A4 leaflet this year via the ECA stating that Smoke detectors in dwellings can be fed via a used lighting circuit ??????
I know and have read the stated stuff about being fed via own circuit etc etc !!!!
Of course in the perfect world their own dedicated circuit is a good idea !!!!!! BUT !!
What about the cases I have seen recently where there is a fault on the detector and the user simply turns the mcb off.... problem solved.
If the detector was shared with a well used lighting circuit this solution would not work !!!
Thus having it in the lighting circuit would make you resolve the problem and not just " switch it off "
Any thoughts !
Any thoughts !
