Smoke Alarms | on ElectriciansForums
Discuss Smoke Alarms in the Talk Electrician area at ElectriciansForums.net
Hi everyone
Been asked to quote a partial rewire and I'll include smoke alarm / heat rise, its for a 2 bedroom bungalow. I'm thinking of installing heat alarm in the kitchen and smoke alarm in the hall. Could anybody tell me if thats sufficient.
Any advice welcome Many Thanks
T&E
1 in the lounge to , one of the most vunerable places is the lounge , way to think of it is you need to protect the escape routes ,as for cable colours use red three core and earth then its distiguished from the other cabling
I actually meant that orange sheathed T&E stuff i've seen about lately...Don't know anyone that uses it mind :-\
it's FP200 after going through the mangle. ( what we used before RCD blowing tumble dryers were invented )
I'm about to start a small 2 bed bungalow. Was planning on just putting one in the hall just outside the kitchen as this is central and all rooms lead off it. Would I still need to put a heat in the kitchen? If so, it would only be about 2 meters away from the smoke?
Reply to Smoke Alarms in the Talk Electrician area at ElectriciansForums.net
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
I've looked at the fire assessment from the last HMO I did for the same landlord and fire assessor, the risk assessment is pretty worthless, it's...
