O
oldbutwise
when fitting a new dual rcd split board the smoke detectors are off the lighting circuit. Does this require a seperate rcbo or can i put the circuit onthe same rcd as one socket circuit ???? :Mr-T:
Discuss Smoke Alarms in the Talk Electrician area at ElectriciansForums.net
Reply to Smoke Alarms in the Talk Electrician area at ElectriciansForums.net
