Smoke alarms | on ElectriciansForums
Discuss Smoke alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
on a new build you have to meet all relevant regulations, 2 core to the fitrst one and 3 core in between them, you don't have to fit them on rewires but I don't see why not IMO as it doesn't cost much extra
off a local lighting circuit there should be a means of local isolation of the smokeys without having to turn off the breaker, a fcu usually
I run 3 core from the board (Making it easier to join onto should you need to add more alarms or new tec comes along) and onto the alarms. I'd use that red sheathed 3 core if I could because it looks pretty ;)
On it's own circuit and try and run it so RCD protection not required
Could you point me in the direction of where this info comes from?
Reply to Smoke alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Thank you all, yes I didn’t think they do and I have done minor works but the helpline was not very helpful. Got my yearly assessment soon so I...
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
