smoke alarms | on ElectriciansForums
Discuss smoke alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
South West
I'm in the process of pricing up a job wiring for a new annex added onto the side of an existing 3 bed house.
I'll be installing interlinked smokes/heat alarms in annex but was unsure whether the existing property would need to be linked to these also?
There will be an internal door that allows access between the two properties so i'm assuming this will require they all be linked as it could be classed as one big property.
any literature i've found so far hasn't been much use, so any guidance would be great,
cheers
Good point Murdoch, if they are Aico or Firedex, you can mix and match wired and RF. So if existing are hard wired, just replace one base for RF to link to new
Reply to smoke alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
