smoke and heat detectors | on ElectriciansForums
Discuss smoke and heat detectors in the Australia area at ElectriciansForums.net
J
james king
on a grade A automatic file installaion.........
do u screw the alarm to the ceiling or use steel inspection to atach it to??
Are you talking about domestic heat and smoke alarms ?
i have to come off a galv steel kind of inspection bend
A conduit system ?
Either way,when you have seen these detectors fitted previously,where were they sited,and who gave you that information
Are we talking about conduit boxes here ?? like angle boxes, through boxes and the like??. As far as i'm aware, if the wiring for the FA system isn't in steel conduit then there's no need for a conduit box of any description.
It is surely down to the requirements of the wiring system and how they terminate into the detectors that determine if some sort of back box is required or not....
Perhaps he was talking about minimum distance off a wall and setting it out or something or other
Your description, if accurate, mean his teachings are alien to any knowlege I have
What is the wiring system?
Reply to smoke and heat detectors in the Australia area at ElectriciansForums.net
This is it though…. To put one following the letter of the law, so to speak… would be a smoke in the hallway outside the bedroom door… then a heat...
Thank you all, yes I didn’t think they do and I have done minor works but the helpline was not very helpful. Got my yearly assessment soon so I...
