Smoke detector advice | on ElectriciansForums
Discuss Smoke detector advice in the UK Electrical Forum area at ElectriciansForums.net
soulman
Durham
Hi, What type of smoke detector would be suited to a utility room. Heat or optical.
Cheers
I meant what is in the room? Aico website tells you what alarm to choose for the different kinds of fires, if it was a utility room with say a washing machine which may have a lot of clothes lying in it, then an ionisation alarm would be best.
Reply to Smoke detector advice in the UK Electrical Forum area at ElectriciansForums.net
This is it though…. To put one following the letter of the law, so to speak… would be a smoke in the hallway outside the bedroom door… then a heat...
Found the cause of the tripping…. Just jointed them through… all clear now. Removed the smoke detectors completely. They were due to be...
