Smoke detectors | on ElectriciansForums
Discuss Smoke detectors in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I
Innominata
Hi Guys,
I have just completed a PIR for a house that has had a recent upgrade.The general condition is very good.The only thing that I am not sure about is the fact that the hall smoke detector is supplied from the nearby hall light,and the landing smoke detector is supplied from the landing light.The two alarms do not appear to be interconnected.Is this arrangement ok or should it be given a PIR code.
Many thanks
Hi,
I am sure that the smoke alarms should be interconnected and battery back up(?). I agree that this should be recorded on the PIR as you have discovered it.
Are they going to rectify the connection?
Best wishes
Rex
That what i was thinking.
If they are, it takes a few seconds from when the test button is pressed on one, for the other(S) to sound.
Hi,
I had a similar problem, I gave it a code 4 (recommendation) and also gave the customer a quote to fit the radiolink bases to the detectors. They are about ÂŁ35.00 each radiolink. The smoke detectors were from B & Q, so did not have the capability of being radiolinked.
In the end I used the Aico smoke alarm units (optical multisensors, with battery backup and can be radiolinked).
Quick and easy and the customer was pleased.
Best regards,
Sav
Hi Innominata,
I must admit the radio link option sounds good and quite reasonable priced. When you did the PIR did you notice if there was three core and earth run between the smoke alarms? I f so I guess it might have been cheaper to replace the fitted smoke alarms if the cabling checked out ok.
Interesting stuff and this forum is great for some sound advice.
Hope this helps.
Best wishes
Rex
can someone be kind enough to explain radio link pls.
to my understanding a fire alarm can be off a lighting circuit if it can be isolated by a spur right??& it cant be on a 30ma circuit neither right??
does radio link mean you only need to supply power to one alarm???
sorry people but fire alarms & extractor spurs in bathrooms stump me!!
In bold:
This isn't entirely true.
Where the use of an RCD can't be avoided it is arguably preferable for the supply for the fire alarm system to be taken from a regularly used lighting circuit as operation of the RCD/RCBO will soon be known (for other than Grade D systems, BS 5839-6 recommends avoiding the use of RCDs on fire system circuits. This will usually require clipping cables direct to the surface or enclosing in steel conduit or the like).
This is from the IEE Electricians Guide to Fire Detection and Alarm Systems
In bold:
so if the lighting circuit is on a rcbo becuse the bathroom lights need protecting by 30ma i need to either do a spur of the sockets for the bath lights & change over cb for the lights or run a radial right?
I don't think you've understood it correctly.
Basically what it is saying is that if you must use an RCD then it is better to run the smoke alarms off a regularly used RCD protected lighting circuit because if the RCD trips you will know about it straight away as none of the lights on that circuit will work.
NOTE: This only applies to Grade D systems which are installed in dwellings.
Reply to Smoke detectors in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
This is it though…. To put one following the letter of the law, so to speak… would be a smoke in the hallway outside the bedroom door… then a heat...
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
