A
APSH
Hi guys, just a quick one. Pricing a job for a customer that is a c/u change, adding supp bond to bath rooms after confirming pipe work needs to be bonded and rejig lights and put in fan and isolation and fusing down for said lights and fans. Also adding a couple of sockets (on surface) and 2 radials for tumble and washing machine under stairs cupboard. Asked if they wanted smokes and was told no. Even tried to convince them of using r/f bases off the lights, but they were not having it. Just wondering if they can be left out as it is not a new build or change of use. All that is going on is my work, new bathroom suites and a bit of decorating to the rest of the house. really want this job as it could potentially lead to other work but don't want to do a job that will not comply with regs. Just wondering on your thoughts. Cheers
