So I'm In A House Today And I Notice A 30ma Rcd On The Wall | on ElectriciansForums
Discuss So I'm In A House Today And I Notice A 30ma Rcd On The Wall in the UK Electrical Forum area at ElectriciansForums.net
Bucks
It feeds an outdoor socket. On the comsumer unit is a 60ma Rcd and everything is covered by this.
I'm just wondering if the 30ma Rcd would trip before the 60ma Rcd trips (if that makes sense)
It's just my mind wondering about stuff, the chap who owns the house said it's never tripped out, yet I wondered if 30 ma would trip first because it's lower than the 60ma in the consumer unit. To me I'm guessing it would?
Anybody helping explain this would mean I might get some sleep tonight without thinking about it in bed, I've tried searching the net for the answer but no luck! :D
Depends totally on the makes of the rcds
Once the current gets around 5-10x the trip setting, they don't get any quicker.
So if the 30mA one trips in 10.4mS (5x), but the 60mA goes in 10.2mS (5x), then the 60 would trip first due to the fault current normally being well above both mcb's 5x values; as the fault current is usually many amps (to meet normal disconnection times) so both are in a race to trip, and once they have started they will finish...
So whichever one trips first is purely academic as they will both operate in similar times
60mA RCD? are you sure?
Not now, it was only a glance because high up. Will make an excuse to have a look again tomorrow. Now if it is a 30ma they will both trip right, or would the closest one go first?
Old Hager consumer unit (approx. 10 years old) , kitchen ring, upstairs ring, down ring, garage, cooker. Lighting is on an RCBO
[automerge]1583438315[/automerge]
Many thanks for explaining that Julie. It was one of them curiosity things more than anything! :)
Ramp test any 30mA rcd and you’ll get different measurements. There’s no reasoning if one is closer to the load or not as to which would trip first.
And if one is “aged” or otherwise of a lesser quality, the tripping threshold could change day by day. As long as it trips before 30mA is reached
I have two RCD in line one at the main DB and two RCBO Lights and socket, in the garage. The garage is 20m from the house on TN-C it trips in the garage if tested. How about that! And lets not get into whys or wherefores on the matter it is just a fact and that is how it is.
aha. trips when tested. may not do that in a real fault scenario.
Thanks for this reply.
[automerge]1583444517[/automerge]
I thought testing was to stimulate real fault scenarios?
Reply to So I'm In A House Today And I Notice A 30ma Rcd On The Wall in the UK Electrical Forum area at ElectriciansForums.net
