socket and light heights | on ElectriciansForums
Discuss socket and light heights in the UK Electrical Forum area at ElectriciansForums.net
P
Paul117
Hi all
About to take on a rewire and my memory has gone a little fuzzy.
Are there any regs regarding socket and light switch heights. It's an existing property with an extension going up as I type. So technically not a new build.
The height regulations only apply to new build premises and not re-wires. However if you are adding an extension this would be classed as a new build and any electrical points placed within that part of the building would fall under the requirement for regulation heights.
Hi Rattle. That's not how I read it re extensions. Have you had problems with BC to state this?
Ref for my reply. Approved Doc M Section 0 General Guidance. Pg 11 0.2, 0.3 and 0.4
Thought DOC M was between 450 & 1200mm not the centre of the switch. I'm pretty sure you can also comply with another British Standard BS8300 with heights between 400 & 1200 if the inspector is a bit fussy. Have a search on google for it.
Reply to socket and light heights in the UK Electrical Forum area at ElectriciansForums.net
ok cheers for the help lads
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
