K
KNIPEX
Hi guys, right before i buy these items could do with your input on them.
first of all the telk 400, which converts an extension lead to a wander lead for checking main bonds are continuous, seems a great piece of kit, not too expensive either,
anyone got one?? are they worth it??
2nd is the sockets and see lamp test kit LTKIT basically instead of unscrewing the ceiling rose you remove the lamp and plug the adaptor in, seems good although pricey, however only has 2 terminals so i fail to see how these can be used for zs where you need all 3.
can you only use this equipment with socket and see testers rather than say a robin/fluke??
thanks for you help in advance.
