Socket distances | on ElectriciansForums
Discuss Socket distances in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
flex_m
United Kingdom
Hi all,
I'm first fixing fancy flats at the moment, started doing some kitchens, I need none less than 5 drawings that all contain mistakes or out of date information, but that's not the point of this post.
When it came to chopping out the sockets, I realised that one will be 65mm from an induction hob and another will be 135mm from the sink. Bought it to the attention of the company responsible the m&e, and although the guy I was speaking to about it thought it was ridiculous, orders from up high are to put them in regardless. I'm more than used to installing things I know full well will need to be changed for whatever reason, but gets my boss paid twice, much to my dismay, but this is the first time I've been told to install something I know very well is dangerous.
Regs wise, I know 7671 doesn't state any measurements in this situation, and the building regs state wherever practable 300 should be allowed. It definitely is practable, there's loads of space above the work surface, I'm 90% sure it's as they want the edges of the sockets and marble tiles to line up.
Just wondering what you guys would do in this situation?
If the socket was at risk of being splashed then I wouldn't install it and insist it be moved or not put in at all.
As for the induction hob, surely the risks of that would be obvious.
It sounds like you are being put in a difficult position - are you signing off the EIC?
If you do decide to go ahead and do as requested, the very first EICR may well give them a C2 and then the fireworks will begin.
I would seek clarification, from the designer, in writing, so if somebody tries to blame you later, you can point the finger elsewhere.
For what its worth, IMHO, BS7671 should include the 300mm minimum!
Given BS7671 doesn't include any recommendations on it, what reg could the C2 be referenced against in an EICR?
I agree. Older OSG's/or 'The electricians guide to the English Building Regs' did suggest 300mm but that appears to have fallen by the wayside (unless there is a more upto date BR guide?).
Insist on a final drawing (otherwise it will all go pear shaped and blame starts being thrown around), get them to sign it off and then highlight the problems in writing and seek instruction from the customer et al.
Dont be afraid to say no if you have to do so. Men have balls for a reason!
Subject to water splash - does that not get covered by IP classification, so no distances in the regs, suggest you just select suitable accessories for the environment.
If I were in the same predicament what I do would depend on what capacity I was there in - if it were my personal details on the certificate I'd want the sockets moved, but if I were in a junior position I'd maybe diplomatically query it once and try not to rock the boat too much.
Doing things properly is nice, but not as nice as job security.
I know for new homes the NHBC says
In the absence of any advice in the appliance manufacturer’s installation instructions, an electrical fitting such as a socket outlet, switch, control unit etc. should be positioned to enable safe operation and to avoid the harmful effects of heat and steam from cooking activities.A standard electrical tting, (which is not splash resistant), should not be located next to a sink or drainer where it could be affected by splashing.A minimum distance of 300mm, measured horizontally from an electrical fitting to the edge of a high level grill, free standing cooker, individual hob, sink or drainer, is considered acceptable for the purposes of avoiding adverse effects from using a cooker, sink or drainer.
http://www.nhbc.co.uk/Builders/Tech...echnicalGuidance/81/filedownload,51128,en.pdf
Reply to Socket distances in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
100% agree here. The likely explanations (poor hardware) is not the responsibility of either the landlord or tenant, as poor quality but legally...
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
