Socket hieght in sunroom cannot be above 450mm | on ElectriciansForums
Discuss Socket hieght in sunroom cannot be above 450mm in the UK Electrical Forum area at ElectriciansForums.net
Coldstream
I'm currently doing a rewire in a house that is being renovated with an extension which will be a sun room, but there are large windows all the way around the room and the highest I can get sockets is 400mm to the top.
Can you still wire the sockets and add in a departure for the certificate? Or does anyone have any ideas to what could be done.
Socket heights (part M) only apply to new build.
[ElectriciansForums.net] Socket hieght in sunroom cannot be above 450mm
Reply to Socket hieght in sunroom cannot be above 450mm in the UK Electrical Forum area at ElectriciansForums.net
