socket in loft | on ElectriciansForums
Discuss socket in loft in the Australia area at ElectriciansForums.net
still learning.
hi, if a customer wants a socket putting in the loft but they don't want there new wallpaper damaged could I drill out the wall at the back of the socket and take the cable (2.5mm 2 core + earth) outside and clip direct the to wall up to the loft?
hi, I'm not actually doing a job like that but I thought I would ask the question because a neighbour has his own business fitting areals normal,digital and sky and he said sometimes when he does a job they need a socket in the loft and he would put the business my way, would this be 3 amp? and if clipped direct to an oustide wall would the ovel plastic be ok to protect it?
Hi if its for an ariel u can take it straight off of the lighting ciruit in the loft its a piece of cake, maybe install a 5a socket so that no one can mis use socket or install a spur and fuse it down
he asked about a socket in loft...! never specified what for until prompted by other members.. but unless its only used for TV amp then yes lights fine but for any thing else i was just elaborating on ezzzekiel comment about how to clip on outside of property
Reply to socket in loft in the Australia area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
