Socket not working anymore. | Page 4 | on ElectriciansForums
Discuss Socket not working anymore. in the UK Electrical Forum area at ElectriciansForums.net
RDB85
Trainee
Liverpool
So last night I noticed that the Socket behind the TV was not working. Plugged in my Kewtech plug tester and nothing. So turned off the MCB for the downstairs sockets. Undone the Socket and its been spurred using new colours from the 13A FCU. Changed the 13A fuse in the FCU, checked the cables and nothing seems out of the ordinary.
There is a socket below that which is wired in Old Colours, which has been there forever. I am just wondering if there is an issue with the FCU, or the wiring itself.
Screwed it all back and then turned the MCB back on. Our house is currently wired in Old Colours, with a Square D CCU. Anyway plugged my socket tester in and again nothing. Would anyone have any ideas what it could be?
Is there any test equipment I could buy to allow me to do some testing, other than a Test Metre as i don't have a lot of money at the moment.
I’ve ordered a new FCU. Going to get it later on tonight.
That might solve the outside light but the switch should have no affect on the spar socket, depending on how it's wired..
Just to add. I'm presuming:
the FCU is just for the outside light, so would have something like a 5A fuse in it and the light wired to the Load side.
the spar is wired to the Feed side.
The FCU is for the outside light. It had a 13a fuse in when I opened it. I am just out at the moment. But I will check how it’s been wired. That should be the case. Light on the load side and spur on the feed side.
Don't you use Tesco Spoon? I thought Spar closed a while back
Some photos. So the old colours are a feed from the socket below. Then added in the new colours for the additional socket
  • [ElectriciansForums.net] Socket not working anymore.
Looks like the spur has been taken from the supply side of the FCU.
So changing the fuse will have no effect.
Need to look at the nearest socket, to see if the FCU is spurred from that and check the connections.
So further investigation. Below the FCU is a socket, which I changed about a month ago, with a new faceplate. Upon looking there is T&E in the back, which is old colours, 3 red (live) 3 (black) neutral and 3 twin and earth. Looking at it I would say that it's spurred from that socket to the FCU. Then whoever has added in the new socket for the has then taken a feed from the FCU using new colours to that socket.
But I am going to collect a new FCU, so I will check the connections. There seems to be no loose connections or damage from what I can see visually. This is probably were an MFT would be of use if I had the money.
sounds like you need to learn how to use a multimeter for continuity and voltage
or get someone who knows what they are looking for
I am learning, thanks for pointing that out. If I could afford a multimeter then I would buy one. Money at the moment is not great. It's also the reason why I am trying to learn how to do it myself. Rather than paying someone with the money, I don't have to go sorted, and then I don't learn anything.
Reply to Socket not working anymore. in the UK Electrical Forum area at ElectriciansForums.net
Assuming you are a novice to electrics? As in no access to electrical equipment. Plug something in to the sockets that you know works else where...
Cbelectrics
C
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
