socket over cooker | on ElectriciansForums
Discuss socket over cooker in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
solo2771
Hi all, been rewireing lighting in house and fitted new CU but whilst there found the cooker switch and socket are too close to cooker ie level with edge of it.
What I want to know is as the client don't want to move it what do I put on installation cert as it is a non compliance? thanks in advance
Paul
Hi Solo,
Your EIC will only cover the lighting circuit and new CU.
Even though you are testing all the installation, as you have put in a new CU, you are not doing a periodic and so the socket is not part of it.
You can advise the customer, but you cant fail it (code1 or 2), as that was probably put there for years before the current regs.
Hope this helps,
Sav
On the EIC, you have a box labelled 'extent of the installation covered by this certificate' in that box, you write 'consumer unit replacement only'.
This then limits your responsibility to exactly that and as Sav said, the offending item has probably been there for years without ill effect so even on a periodic, it would only attract a code 4.
Reply to socket over cooker in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thank you for fast response. The reason I asked is because I had read elsewhere online: "Electric ovens have a wattage rating that tells you how...
