H
hightower
In the canteen at work they have an old MK isolation switch which operates a hard wired mixing unit. Both the switch and the mixer will be going to Beamish Museum (Google it) they are that old.
The isolation switch is next to a sink, as in, 20cm above it, and <5cm to the right of it. Well, not the sink, but the draining board as part of the sink. The tap is a swivel design though, so can rotate to over the draining board.
There's nowhere else along this wall (it's all windows except for a 12" pillar where the current switch sits) that a socket can be fitted. Anyhow, to the point now.
They have a new mixer, it plugs in with a 3-pin plug. They wanted this MK isolating switch changing to a socket so they can use it in the same place. I told them I couldn't do it due to the proximity of the sink. They questioned about the switch there and asked how long it had been a rule, and all I could answer with "I don't know, but regardless, I wouldn't want a switch that close to the sink". Probably more so because this is a commercial kitchen, not some tidy old woman in her house.
So, from my description, do you agree with me? I've told them I can remove the old switch altogether but I would need to fit a socket some other location.
