Socket shows LN Reverse on socket tester | on ElectriciansForums
Discuss Socket shows LN Reverse on socket tester in the UK Electrical Forum area at ElectriciansForums.net
lknights1987
Adaleighhh
Hi all,
I have recently moved into a flat. One the single sockets shows LN reverse on the socket tester that I bought today Why could this be ?
I have checked the earth connection which is all good.
Because you appear to be getting a reading before the socket switch is on this would indicate that the switch is not switching the line but instead is switching the neutral, which would be consistent with telectrix's statement above.
A simple, but potentially dangerous, wiring error.
Thanks for your replies to my comment. I think I have found the problem! One of the double sockets in the living room the earth cable had fallen out.
I’ve attached a photo. Why would the earth cable go into a connector in the block and then into the back of the socket connector? Can I run the earth cable straight into the socket ?
[ElectriciansForums.net] Socket shows LN Reverse on socket tester [ElectriciansForums.net] Socket shows LN Reverse on socket tester
It looks like one earth is connected to the socket and the other to the earthing terminal in the backbox. while this is not correct practice,when the socket is screwed back both earths will be joined, so I would doubt this is your issue. From your original post it would appear that the L and N are simply in the wrong terminals in the socket, have you checked that?
In all living room sockets the earth cable was out. I’ve put the earths back in but I’m getting the following voltage readings on one of the double sockets
between live and neutral 243volts
live and earth 141volts
neutral and earth 103 volts
all cables are in the correct connection slots on all sockets
seen it before with these testers ,usually is an earth fault . not reverse polarity
Yes, when you think about it, the simple tester probably reports a voltage above say 50v between N + E as wrong polarity.
Reply to Socket shows LN Reverse on socket tester in the UK Electrical Forum area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
I'll try and get around to it :)
