Socket spur | on ElectriciansForums
Discuss Socket spur in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Scotland
Had a ring circuit with a spur feeding a 2 gang socket coming directly from the 32a mcb. Ring main has since been stripped out and just left with the spur. I have now fitted a 2 gang socket in 4mm directly below the cu, is it still acceptable to leave the 2.5 spur coming off the same 32a mcb?
Yes as long as it is only for a single or double socket outlet or FCU.
Reply to Socket spur in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Haha yes, it is. Must be a northern expression. Have a Google 😂
Cheers guys, enjoyed reading all the responses. I'm an apprentice and it was a conversation that came up at work between two electricians...
2 3
