R
rallyandy
Hi all
just a quick one, what is the best way to install two sockets in lounge for table lamps only as the owner wants them switched from a double switch plate. do i feed off the downstairs lighting ring and put a fused spur in line before the sockets with a 3A fuse to stop the lighting circuit being overloaded by plugging the wrong things in to the sockets (as people do) or should i feed them from the downstairs ring main through a fused spur then up to the switch plate ? .... any suggestions would be aprreciated as i normally do commercial
