Sockets minimum heights | on ElectriciansForums
Discuss Sockets minimum heights in the Australia area at ElectriciansForums.net
B
baldsparkies
My first question (Please be gentle) :D
I have a customer looking for a complete re wire no problem there exept they are insistent on the sockets being no more than 300mm from finished floor level.
Now I must stress the property is some 30 years old so its not new build ,as far as I am aware I can see no reason why I cant accomodate there request, not so if it were new build because of building regs 553.1.6 and section 8 of document M.
I cant find any referance that would tie older properties to the above regulations and would therefore consider them exempt, also I can see no problem at a 300mm height with cord strain access or reach.
The property is not on any known flood plain so I feel safe to go, However now I have joined this group of fellow sparky's I would appreciate your thoughts and comments on this.
Thanks in advance lad's and lasse's.
Hi Mate
If you are doing a rewire nothing to worry about however on a new install sockets must be a minimum of 450mm from the finished floor level and on top of work tops the centre of the sockets must be a minimum of 150mm from that surface
Hope that helps
Chris
Thinking about it the only time 300mm and sockets are mentioned as far as I can remember is the minimum distance away from the sink, so providing its as per the above post I dont see a problem
Chris
Its page 137 of the building regs book just above the piccy and states The guidance given in Approved Document M applies to all new dwellings and goes on to say if a building is being rewired their is no requirement etc etc. I would think what they are saying is no need to move them but if you are moving them from the original location for whatever reason then the 450mm from floor level applies.
Hope that helps
Chris
Well, from what i can see in Part M, it males no reference to either new or old dwellings.
Unless im missing it somewhere..
Also section 8 of approved document M under the heading Where the requirements apply,
0.1 New Buildings
The reqiurements apply where a building is newly erected or has been substantialy demolished to leave only external walls.
Also referance in the onsite guide appendix 8 8.6 refers to new dwellings.
I cant find any referance to older buildings though jason, so fairly confident the customer can have their 300mm height without contravining any regs.
One company turned the job down because of this. Said it was against 17th edition regs but I think they have got it wrong.
There loss could be my gain can,t afford to turn work down these days not without getting facts right;)
However they could be right if you are moving the sockets from their original location the only way you are going to solve this one is speak to building control as they are the ones that will quote the 17th regs at you if you do it wrong and may even take it to court.
Chris
0.1 New Buildings
Thanks chaps.
Thats my problem.
I need to learn to RTFM.
I generally only scan them when required:D
Did a lot of reading last night and it does look good to go.Most of the sockets are at 300mm now so really cant see a problem there. The odd sockets in the skirting boards are a definate no no, but those can be raised to the hieghts of the other sockets ie 300mm. In fairness moving the sockets upwards from the skirting boards could only be deemed an improvement on the original install.
Many thanks to all guys for your input, very often when new regulations come into play, you find its not what they say that causes confusion its more what they dont say.
Thanks again
Reply to Sockets minimum heights in the Australia area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
