soffit downlighters | on ElectriciansForums
Discuss soffit downlighters in the Australia area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
as title. got a job on , 1st fixed today, client wants 8 downlighters (GU10 halogen) switched with PIR fitting in his new pvc soffit. been on to meteor, and they say most guys use IP rated shower lights. is that the best solution, or is there anything more suitable.
IP 44 would sure surfice under a sofit.
The other thing to think about with these things is the condensation created by the halogens. I know there's airflow in the soffit, but if it gets too bad the back of the fittings aren't ip rated.
I'd also be taking note of the lamp output fitted. PVC has a habit of melting at high temperatures so 35W lamps max in accordance with the usual F mark on such fittings would be a wise decision. Personally i'd fit LED fittings if it were my place.
was going to go for 35watt lamps due to the possibility of the pvc soffit getting warm. not sure if LEDs are suitable for PIR use though. have told client he can replace with LEDs, bu need to ascertain if th PIR can handle that type of load. generally, PIRs like a purely resistive load.
PIRs can be a bit of a pain with unusual loads. I've got a Timeguard Professional one operating LED fittings at the moment which seems to be coping well. I've also got a Busch Watchdog PIR on another job doing stirling work but they are mega bucks compared to the Timeguard.
robus pir and led lamps if possible if you have to cut cost id say go with different lamps not different pir's. if you are going to put 50w halogens in you might have problems mind as the plastic soffit will just heat up and with the force of the springs ends up turning the lamps into recessed lumps of very warm plastic
Done loads of these and use shower downlighters, and a 4watt Led G10. Good light cheap to run and last forever. Does not get to hot as to affect the facia or discolour it., they work well with standard photocells.
Reply to soffit downlighters in the Australia area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
