Sofit lighting | on ElectriciansForums
Discuss Sofit lighting in the Electrical Tools and Products area at ElectriciansForums.net
Im wanting to fit a few GU10 downlights in a PVC roof soffit, they will contain LED lamps so heat wont be a problem, but
what is everyone using?
Any recommend a fitting?
Reply to Sofit lighting in the Electrical Tools and Products area at ElectriciansForums.net
Are you sure you're competent to do this work?
You will notice that the individual output of the most efficient LEDs on your data sheet is very low compared to the less efficient ones further...
